Notifications are a mess. Would be great to have it solved.
I’m not so sure I like it either, but I’m sure I’ll get used to it. It’s down to the Discourse platform so it can’t be changed from here, and for security, updates have to be applied.
I think mainly and for me it was flooded with old notifications but now I’ve pressed “dismiss” everywhere and hopefully it will be easier to track onwards ![]()
Good tip thanks, that seems to sort it out. I was getting notifications from months ago ![]()
Great tip thanks that has sorted my notifications.
Yes, it seems to have reactivated some old notifications. Easy enough to dismiss, as you have found.
I still have issue with all notifications remaining highlighted, so I can’t distinguish from ‘Replies’ I’ve already seen and responded to and those I haven’t.
Even though you’ve pressed the DISMISS button on all categories of notifications down right?
Yep
Me too - grrrr
Not a fan of the new drop down…makes it impossible to track the threads where I have been active.
I am getting exactly the same
I found applying the dismiss button helped .
Thank you - it appears to have cleared the masses of good / nice reply messages.
Which is the Dismiss button?
I found at the bottom corner, it has now disappeared …
All these years and it still gets cocked up. I’m tempted to get my free forum fun elsewhere!![]()
HAVE YOU TRIED LOGGING OUt.
THEN LOGGING BACK IN AGAIN.![]()
I’m now getting notifications of old ‘replies’ to my posts I made a year ago, in a thread that’s been officially closed…
WTF ![]()
