Fraim/ speaker connection
Hi all
Happy new year
Just starting to build the Fraim and now worried about the connection to the power amp
Should I have naim plugs or bananas as I’m thinking about cable routing
I’ve tried the system pics thread but they are all front shots
What power amp do you have? Naim plugs are fine, but normal bananas will do with most naim power amps.
Naim plugs. Transformed the 600s after an upgrade from Linn Keilidhs. Make sure that the metal of the pins is the same as that of the sockets.
With Naim’s right angled bananas you will need to bend the cable outwards a bit so that it doesn’t go straight down onto the glass shelf below. With NACA5 it will retain its shape once you’ve bent it. Assuming you have a Naim power amps, the supplied plugs are a good match.
