My second PS555 comes next week. As a result of the forum factory visit. I wanted the difference to not be noticeable, but sadly it really was. My suggestion is to not listen to it with two if you want the 4 grand or so its worth second hand. If you do you won’t be selling it.
I believe v3,8 will not give you Tidal Max, but I’m happy to be corrected.
Try it! When even not optimal, it will be very much better ![]()
If it is still on 3.8 you should think twice if you press the update button for tidal
Isn’t the flat top mounted on spiked legs like the shelves below, suggesting it’s designed to have units sitting on it……..?
Enjoy and a fun Christmas for you
That would work. It just doesn’t have the glass isolation shelves and it would upset the aesthetics.
To be honest I’ll just probs move the PS on and give myself another upgrade opportunity when the time is right…
@Stu299 If it was the one from eBay coming from the uk which was there since spprox 1-2 weeks, than it is on 3.11. i asked ![]()
Haha are you checking every ND555 that comes up for sale in search of the 3.8 holy grail? That’s dedication!
The one I’m buying is from eBay/UK and it comes with a 555 DR power supply. I did ask them about the firmware and they said they didn’t have a clue.
Yes i do that - that desperation and dedication
I’ve measured carefully and 2 x 555DR would fit direct stacked on the bottom right hand shelf. I’m thinking isolation of power supplies from each other is much less of an issue than isolation of PS from head units.
It may well also improve the aesthetics, because it will get rid of the gap
Did the one you enquired about come with a PS?
I dont think it has.there is hope for Your nd555 ![]()
If it is and I become rich overnight, I will gladly send it to you ![]()
I think if you use some isolation pucks it will not be an issue. @JosquinDesPrez is your main friend here. He has new HRS racks and has stacked his Naim components very nicely.
Thanks Dan. I only have 7mm clearance to play with but I’ll see what’s available ![]()
Yes, I use HRS 1” Nimbus dampers between stacked components. I have 252 on top of 300 PS and SCDR on top of 300PS. I also have NDX2 on top of XPSDR, but that one doesn’t matter since I have it listed for sale. I’m replacing that with a single half-chassis DAC.
That’s not much at all to work with.
Why is it the system never sounded so good, just before you make a change ![]()
This is always the same. With cars also.
