Hi can I just check - is this where the fuse goes (and the spare goes in the holder to the right)? The amp goes on when the fuse is placed here and not when in the holder to the right so assuming that the spare fuse holder is to the right of the fuse in this picture? Many thanks
I can’t recall offhand if the R or L socket is the one. Not changed the fuse for a long time. But the fact that the amp powers on in only one of them is the clue!
Yes, that must be right!
Do you know what fuse should be used for a 250DR? I just want to double check as I’m selling it and want to make sure it has the correct fuse. The fuse I have in it is: LF.T3.15AL250VP. I think that’s the right one? Cheers
Whatever Naim say on the rear panel…
This does vary, with the particular 250 variant… ![]()
Even Naim Support got it wrong in my case… But @NeilS got it right…
Thanks very much all, much appreciated!
