Jimdog; bit of ambiguity in the second package listed; 3000/4000 series nvidia (could be the x050 variant graphics cards, rather than the 4060 series card in the cheaper rig…)
for games, mostly held back by gpu for performance -unless looking at super high refresh rates/upper price point stuff, a better cpu will ‘not hold back’ a gpu in some instances
fortnight is unreal engine 5 and scales well to whatever the end user wants to do; eg I opt for all the eyecandy and settle for 60 frames per second, where as more serious competitive gamers, who will generally opt for for higher refresh rates, even of that means turning the eye candy down a little.
likely the first package, with the 4060, is a good match for the monitor, and those games- spending more won’t render better, so to speak…
(and fake/false economy to pay more for ‘future proofing’ when the gamer enjoys easy to render games, and isnt trying to hit 4k at high refresh rates…)
as a gaming PC veteran, having had many many of the parts from both greed (ahem ‘green’),red and blue teams… I will certainly vote with my walletand buy AMD every time.
the 825£ package having an nvidia gpu is what the monitor will marry up well with (but check if monitor is “freesync” as AMD GPUs like that)…
if monitor isnt freesync capable, do what just about every gamer does and buy an NVIDIA card… (variable refresh rate support is very worthwhile)…
gsync is nvidias variable sync to the monitor tech (akin to freesync), and so a 4060 gpu is a good target tier of card in terms of doing anything you can throw at it…
(I’d go AMD 6600/6700 and 7000 series GPUs, personally, due to that is what is in the gaming consoles and is a huge benefit for the underdog gpu maker)
the cpu so long as 6core/12 thread capable will probably not seriously hold back a GPU for a few years yet
lionshare of games are made to run on consoles, and the present consoles dont seriously challenge decent CPUs available…
a 4060 is a much much better graphics card than a 4050, and even paired with a much less impressive sounding CPU, will absolutely thrash a 4050 gpu at any game played.
for high refresh rate, the 4060 will be a good ‘minimum tier’ to invest in…
(equivalent AMD cards being 6700 and higher models (6800/6900,/7000 series models), but go better with a Freesync capable monitor).
16gb ram
6core+12 thread cpu
nvidia 4060 series card (good minimum spec)
well done finding that config for a tidy pricepoint!
