Hello All. Have a shiny new NDX2 … trying to get it to play Tidal without success. Suggestions welcomed.
What have you tried so far to get it to play from Tidal?
If you open the Tidal input, you should be prompted to enter your Tidal account details. If not, go to Settings > Input Settings > Tidal and log in from there.
Have you installed the Naim app? Then go in settings and enable Tidal.
Thx. Got it sorted now. Clearly this is going to be a slower process to get up and running than I expected. A physical manual might not have been a bad idea.
Regardless, welcome to the Forum!
This link may help. Under Support try the NDX2 Support Topics:
