It’s going to be mounted on to a SME mount then mounted on to a Michell Orb (not mine)Will have a 9 inch wand. My Question is, what would be an appropriate torque setting for the 4 mount bolts 1Nm?? Sorry Big $$$ so OCD strikes again.
NOTE: The grahams 10 inch wand will not work with this Orbe SME setup for those going down that same path, it’s been a real nightmare as was advised incorrectly by the importer, 6 months later and a small finger pointing scenario the 9 inch showed up!
It is possible to get an acrylic mount that will work think it’s made by Michell.
@fordy has a Graham Phantom. May help perhaps.
I didn’t know it was so important to have the right torque for the arm.
Is it the same for my Rega RB3000 on my P10?
I’ve never seen any advice on the bolt torques. Mine are something like M5 panhead machine screws on a Graham mount so you can’t get much on them anyway. I just nip them up.
Thanks, Yes I reckon you’re right. I’ve come to the conclusion a nip up. I think 1 Nm is a nip up and because I have the tool to do it why not. I was just bit concerned it’s not enough to keep it in place seems how it’s mounted into channels or whatever you call it. I just get a little trigger happy with my torque wrench at times. All me nuts have had dose
Cheers men.
