Yes, I’ve been away for a few weeks but I was a bit confused too, just checked the app store and looks like it updated on July 29th, guess it auto-updated because I didn’t tell it to, haven’t had time to check but I sure hope the Tidal Hi-res update was included in this update!!
Also when you move from an old phone to a new one, the settings and user data gets transferred, but the new phone downloads the apps from the app store again. So you will always get the latest apps in that situation.
Since this last app update I seem to have lost the Naim Styles option that gave various fancy background display options and I only have the appearance options of light dark or automatic. Quite probably my tech incompetence but I am failing to find the different style options…
Thanks for all the replies.
Never knew that switching phones installed the latest app version (even if auto-update is off).
New version of the app seems to connect better to the streamers (we will see).
If you are wondering I went from samsung A23 to S23 mainly so I could use google maps in bright sunlight. (Bought it on amazon – unlocked – for £500).
It would be nice for naim to send me an email about the app update.
Also it would be nice to be able to go back to older versions.
As I said the new version seems to connect better so I am happy with it.
If Sonos’s response to their app making some people’s speakers unusable is any indication. I’m guessing that it’s more complicated than we realise to offer multiple versions of an app. It certainly would have saved them a lot of hassle to be able to offer an older version of their s2 app.
On Android that’s always an option if you sideload the apk. That’s what I did for a while with the abomination that is the new Sonos app but alas they’ve closed that off as it now does a minimum version check.
Offering less features with an update is progress apparently . It doesn’t really bother me but considering the App is used in lots of lifestyle products such as Musos I’m a bit surprised.
