There is no way to select HDMI on my Uniti Star. Can anybody explain how to get to the HDMI INPUT.
If you have a correctly configured HDMI ARC device connected, the sound should automatically be routed to the Star through it as long as the input hasn’t been turned off in the Naim app settings.
As Chris says, have you got the input turned on? If not, you can turn it on by going to the Input settings section on the app.
Thank you very much, I’ll check it out in the settings. I initially went into settings but didn’t see anything regardiing HDMI in settings.
Hi ChrisSU, thank you very much for your help. I did what you said and that worked. Hope that I can help someone in the future, so that I can pay it forward. Thank you w
I think that the problem is that the TV won’t send a PCM signal in 2 Channel stereo. Only multi channel PCM.
The HDMI has to be controlled from the source feeding the Star.
My BLuRay player now outputs in stereo only . Wonderful
I would look at the menu for your TV and if that has a digital output switch it to stereo
