I have a interesting question, for some reason i can not get the back up function of my HDX working, i have a external store and everything is now covered into flac, so it will all fit on the internal hdx hdd.
i would like to move it back to the hdx but keep a copy on my nas. i will not be ripping any new cds. i don’t want to move it and then make a copy back on then as, i just want to make a copy to the hdx
Is the external store functioning as the designated ‘music store’ that contains CD rips made on the HDX?
Does your HDX have a downloads folder as well as a music folder? (It should, unless it’s a very old one which hasn’t been updated.) If you can locate the downloads folder on the internal hard drive you should be able to copy the music files onto it.
Phil, I am also a little confused…can you provide a simple explanation of how to back up the Unitiserve with a view to being able to transfer that back up info back onto the Unitiserve after breakdown or whatever ? thanks steve w.
It’s a very complex process…
Set the HDX / UnitiServe to backup to a shared folder on a NAS.
Listen and enjoy.
If a problem occurs where you have to restore the music from the backup folder to an HDX or UnitiServe then simply allocate the backup folder as a STORE and move the music from the store to the HDX / UnitiServe - then go back to step 1.
Running a server and Roon certainly will eliminate some of these “rules” by which the Naim servers work - which by 2020’s standards do seem outdated.
The Naim ripper/servers I’m sure were designed that way to prevent/reduce customers messing up the data; locking it down made some sense. To the expense of making other operations, such as getting the backup set up, more complicated than by today’s standards it should be.
