I want to buy headphones for some listenings and intend to use them with the DAC-V1’s output.
What type of headphones matches the DAC better? I know there are all possible types, but first high or low impedance? I tend to prefer closed types, but accept any type of suggestions.
I don’t think the DAC V1 is going to ‘match’ specific headphones (or not). Looks like a reasonable spec on the output to me. Comes down to personal preferences, budget etc. As usual a demo is pretty essential in my view, not just for (suprisingly divergent) sonic characteristics but also comfort, which is very individual.
Thanks to both. Bruce, I meant about high or low impedance. But yes, the DAC has a single-ended Class A headphone amp onboard, so it’s down to personal taste as you say. My dealer has a lot of headphones so a demo will be easy.
M.
I have these and they are a good safe bet. However, after a few years running these on the end of my DAC-v1, I was curious to hear what I could with a more modern design for under £1k. Focal Clear MGs were slightly out of reach.
My local dealer let me home demo three sets against my HD600s - Beyerdynamic T1 (3rd gen) (open back) Beyerdynamic T3 (3rd gen) (Closed) and Quad ERA-1 (open).
I try to recall the detailed results but the Quads were streets ahead (overall) for me in terms of:
• resolution and texture - you could easily tell minor differences between each drum type in a kit;
• dynamic range - a fuller, slightly more expansive soundstage, with an instant ability to scale in louder passages;
• musicality - prat retained, good engagement and sing-a-long factor the best of the four.
• better defined bass - less warm (coloured) than Beyerdynamics but still punchy.
• excellent engaging mid-range vocals;
• visceral sound signature on rock guitars which I like.
The HD600 sound was very good but the other three took it to another level with non-classical. I felt the T3s were closest in ranking to the Quads but in all areas the Quads were more preferable (and cheaper to boot!). Ranking: ERA-1; T3; T1; HD600 (albeit my pads and headband are pretty well used/tired and will be replaced).
Quad comfort is the only area that is ‘marmite’ per audio press written reviews, however I wear mine for 3-4h at a time and find them extremely comfortable and slightly prefer the lamb skin pads (velour also supplied in the box) for sound quality. They are nominally fairly weighty but I don’t find them at all uncomfortable. In fact they soon ‘disappear’ on a number of fronts!
As you can read I am very pleased with mine (had them a year from new) and highly recommend them to shortlist for the DAC-V1 and dare say other Naim headphone outputs. They are very easy to drive and go plenty loud enough without ‘collapsing’ under pressure. They are a planar design and imho good looking and of good construction quality.
I imagine* they would be very close in overall SQ to Clear MGs, however a tad further behind Stellias and Utopias (but these are 5-7x the price of the Quads), but sense the Naim headphone amplifier may become the limiting factor.
Focal Clears heard through AtomHE; Other 2 through Nait 50 fed by ND5XS2. Same track used that I remember the musical engagement well. This was at Bristol Show ‘24.
I would recommend a home demo of your shortlist and wish you well in your choice. Please let us know what you choose and why, when you make the decision. I enjoy my DAC-V1 and don’t think I lose much compared with the HE except the built in streaming board. However, my newly acquired ND5XS2 more than makes up for that and my future system steps.
My DAC-V1 drives my ageing HD600s very well for a high impedance set. However, my very low impedance ERA-1s sound much better all round and go much louder without collapsing - so no fear of the easier to drive compatability compromising overall enjoyment.
I had Quad ERA1 too, when i first started 'serious ’ headphone listening. I tested them against several others including Sennheiser 800 and found them just more enjoyable. The Senns were technically better (and more expensive) but I found myself listening to the music more with rhe Quad, and the headphones more with the Senns. If that makes sense! Others love the 800 (and 600) of course.
I have got rid of them as I have spent more, and added a good headphone amp etc.
I have a soft spot for Grado, having owned several models. The RS1 is a sweet spot in the range, again not technically the purest but very much a toe tapping and engaging listen. Try to audition if you can. The comfort is ‘odd’ but you do get used to them!
Can wise, i have Senny HD600 and 25s. And Focal Clear Pros ( red pads and 5m coily cable). To be fai the Focals are wired with a balanced cable most of the time. But, they have been used via the 1/4" TRS jack into the V1.
So yes, the Focals are better than the HD600, ( 32 ohm as opposed to 600ohm), but i was slways inpressed how well the v1 drove the hd600s. I have heard the HD600s sound dire from £300 headphone amps.
So will the v1 make the HD600s sound sound good? Yes. And new headband and ear surrounds are cheap for the HD600s too.
Yes, the HD600s are a safe bet at the modest price and reward a ‘strong’ headphone amp like the Headline and that in the DAC-V1.
In fact, prior to the home demo the Beyerdynamics walked all over the Senns at the dealers. They (Senns) sounded like ‘cheap toy ‘phones’ and that was via a Qutest into a (same form factor) Chord headphone amp (sorry I forget the model, except together they were over £2k).
Worried, I was relieved when my DAC-V1 restored my faith and enabled me to properly audition the demo sets in my home system, and whilst the HD600s sounded very good as I was used to, the others were better and especially the Quads.
The OP should hopefully avoid compatibility issues as the Naim headphone amp proves it can cope with a wide range of hard and easy to drive sets, unlike some of its near competition .
I agree with Bruce on Grado headphones. I use the ‘limited edition’ Hemp 'phones with my Nait50, which I imagine must be pretty similar to the DAC- V1, and they’re bloody good.
I have a soft spot for Grado too, in general - I also enjoyed their cartridges, but love for the brand is not universal…
I’ll check a few of those suggested. Thanks to all for their help.
M.
My dealer is exactly halfway between home and H, where I have Radiotherapy. I’ll stop by @ the shop tomorrow on the way back and will listen to something.
Reports coming.
M
