I have bought a server and connnected to the router. Downloaded some high quality tracks. I have selected UNPN but can’t find the server. The server is a WD my cloud home, and connected through sky broadband.
Any help please
Lee
Any help please
Lee
I think the WD MyCloud Home isn’t a server. It’s a network HD Store?
If you can run upnp server software such as Asset, for example, on the WD device, then your SuperUniti will be able to see it.
Best
You can run plex on it, instructions here.
https://support.plex.tv/articles/115003310834-western-digital-my-cloud-home/
