Hi, does anyone have experience with Rel subs and the arrow wireless module? Specifically how to connect as Rel recommend connecting to speaker terminals. Are you connecting from a sub out RCA or do you need a banana plug adapter so speakers and the Rel neutrik cable are connected together? My amp is a Naim XS2.
I also got the same problem with my Nova. How to connect a Rel with the Nova using the Speaker level connection.
Another forum suggested stackable banana plugs. Just ordered some from eBay (my Rel arrives next weekend).
