May be worth having a demo of the Naim NAC A5 cable along with kudos KS-1. Both work well with Naim.
DG…
DG…
Thanks, it wasn’t mentioned in the system.
No , sorry an oversight on my part.
Update …
Naim dealer kindly repaired the speaker cable and plugged everything back on today.
Vinyl plays beautifully on both channels but still no left channel on CD - which was the original problem.
I’ve tried the 5 pin din into tuner output and exactly the same.
So, i’m thinking that it’s probably a refective 5 pn din connector ?
However, the CDX2 is powered by a pretty new XPS DR ( only about 12 months old ) and i’m wondering if that has different circuitory for both cannels and could that be defective . Please don’t get upset at my amatuerish question because I have no understanding whatsoever of the technicals.
So, If I can find the original blanking plug and power cable I could revert to using the CDX 2 bare , by pass the XPS and see if that works ?
It’s a total mystery because the right channel on CD sounds absoloutely wonderful!
TIA
