I’ve this nDac which had an older firmware version (done the Apple iPhone thing)
I have:
- found the webpage with the link to the 4.11.8 version
- downloaded the file
- copied the files to a USB stick, removing the empty folder and the instruction .pdf
- turned the Dac off, disconnected the mains cord and let it rest for at least 15 minutes.
- Turned it on again, waited for the lights to settle
- inserted the USB stick.
All the five lights went on, but stayed on. After one hour, nothing had happened. Stuck.
So I:
- turned the Dac off and disconnected the mains cord.
- downloaded a fresh file directly to another, better USB stick.
- removed the .pdf with instructions and the empty folder. The five files were ok.
- turned the Dac on, but at this point:
The five lights were still on before the USB stick was inserted.
I inserted the stick. Nothing is happening. I did it at least fifteen minutes ago and it’s still five lights on and nothing happening.
What have I fu**ed up?
Thanks.
