I am using chord shawline X f#### expensive are they OK or do I need NAIM ONLY CABLE ,many thanks
Shawline is fine with Naim electronics; I don’t think there’s anything in the chord range that is so out of spec that it will affect the amps.
OK many thanks for your reply , I just had an oh oh moment I wonder ?
The Chord cables get significantly better as you move up the range. I started out with Shawline and I think the OP will be fine. I was not impressed with Naim cable. Some members really like Naim cable. I have never tried NACA5. Too inflexible for my installation. I have only tried the default interconnect.
The Naim cable is provided with the 250, so you should have one that you can try in comparison with your Shawline. If it was missing you should ask the seller of the 250 to provide it.
Is your Shawline a DIN to XLR, which would likely be a custom built cable? You should be using the DIN out on the Uniti.
Naim: very good at synergy.
Chord: made for Naim.
Buy, listen, choose.
