The image shows how a Hicap and Flatcap are connected to a NAC 152x. Does it matter if I connect power out A to the pre amp and use B to power the CD5?
Thanks for your insight.
not really but what is the hicap powering in your system?
I’m not really sure but if you want to follow the diagram you could simply use A to power the CD5.
I just wanted to make sure I could use the spare power out without causing any damage.
The Flatcap can power two things quite happily, so there is no need to worry.
