The DIN socket # 3 on my HiCap must be bent. I can’t plug in the DIN cable into it, but it will plug into the others. Socket # 3 is the one used to go to a stero power amp, which I have. Socket # 2 is for a second mono amp, but can I use it until I get this fixed? Thanks
You can use 1 or 2 quite happily.
Great. Thans
