Hi. Please, is the cable that comes in the HiCap DR box the 5 pin DIN cable that is depicted in the Connection Guide - Amplification, the one in green? And so the 4-pin cable would be necessary only to connect the Supernait 2 / HiCap DR combo to another amplifier, like the 250 DR? This would be the one depicted in black. Am I wrong?
If you are connecting to a Supernait2 or a NAP200 power-amp it’s the SNAIC4 (4pin to 4pin) - sold separately for a Supernait2 connection or included with a NAP200. For a NAP250 it’s a 4pin to 3pin XLR cable (which the 250 comes with).
A Hicap comes with a SNAIC5. If you wish to use the HIcap to power the preamp I’d a Supernait then you’ll need an additional SNAIC4. If adding a Naim power amp then the SNAIC4 or DIN4-XLR lead comes with the power amp
