I’m looking for a HiCap to connect to my Superline or Supernait 2 (perhaps one each!?). Are all HiCap boxes the same until the DR upgrade came along, although with different look?
Would for example an olive HiCap be good value for performance with the above components, if one should show up? Or is it better to just get a DR version at once.
Hi caps be they CB or Olive are essentially the same. I’ve not seen inside a post 2005 hicap, but I’d expect it to look similar too. In short just a change of box.
The hicap dr will be a step up. If you want the best performing hicap power supply, this is the one to go for. However, even preened, they are not cheap. Expect to pay £800 plus. Double what you could get a non dr for.
I went from a cb hicap to a hicap dr with my 32.5 / 160 and for me the dr had all the energy of the cb hicap but added a focus and sweetness to the sound, if you know what I mean arry
I think that question was asked when the DR HiCap was first released. If I remember correctly it wasn’t possible but @Richard.Dane would probably know for sure.
Thanks for the clarifications and input on HiCap/ DR. I will try to demo a HiCap DR or perhaps just go for it, if one should show up second hand. They do seem a bit rare here in Sweden though!
It also seems I might just started on the slippery slope to a Supercap… Yankfish do you mean Supercap with DR as well, or non DR? Looking around I can’t se a Supercap DR close to anything for a HiCap DR… Also some places suggest there is a Supercap 2.
I guess I might as well ask for input concerning the experience of going from a Hicap DR to a Supercap DR or non DR with a Superline!
There’s the original Olive Supercap, then the Supercap “2” that came with the current black anodised aluminium facia, then the Supercap DR with Naim’s discrete regulators. Even the original Olive Supercap is a superb power supply, although be aware of the important 8-10 year service intervals, to ensure optimum performance.
the superDR is pretty new and very expensive, a plain super2 is fine
hicap to hicapDR is a minor upgrade at best and i imagine the same with the supercap especially since a supernait2 isn’t going to show all the nuances anyway it’s a waste of money probably
I’d like to see a regular hicap and then hicap dr’s noise trace on a scope. Especially on load.
The regular hicap has a massive 400/500 va transformer. Coupled to 2 bean can caps.
Who on earth came up with this? Massively overspec’d. The transformer takes up half the box. The on on the 140 is small by comparison.
I’m sure dr is icing on the cake. But far from essential.
I think the decision not to offer DR upgrades for Olive or CB was purely commercial/political. The insides of the pre DR classic look identical to its predecessors.
