HiCap Positioning
Quick question: Is it ok to locate 2 HiCaps side by each on the same shelf of my rack. It was suggested that on a 3 shelf rack,I locate my 2 HiCaps on the bottom shelf, My 250 on the middle shelf and my 282 on the top shelf. The Napsc is located on another shelf. Thanks Tony :canada::england:๐Ÿ‡ฌ๐Ÿ‡ง๐Ÿ‡จ๐Ÿ‡ฆ
Yes.
Perfectโ€ฆ!! :slightly_smiling_face:
Thanks for the info, it was a dealer that suggested it but a friend who is into electronics said no.
The dealer is using Naim logic - Power supplies low, Pre amp high.
Yes, they sit nicely together
DGโ€ฆ
do you think it is better to put hicap at the bottom than power amp?
Yes. PSUโ€™s should go low.
here you have power amp at the bottom, correct?
