Just collected my repaired HiLine from my dealer.
Am I correct in thinking I can re-install it without a power down? Just mute the pre and select a different input?
Steve O.
I’m sure you’ll be fine doing just that, I’ve certainly done the same on my system without issue.
Yes I’ve done it too
Though I’m sure the advice is to power down…
