Hi All. I’ve got an LP12 (Ekos 1, Karousel, Core and Radikal) playing into S Boards in my 52. I had to change my Arkiva (which was dying) earlier this year for an AT F7 (for financial reasons at the time). It’s been a good little performer since then. However, over the past few weeks, I’ve noticed a considerable hissing through the speakers when the volume is only at the ‘9 o’clock position’ on phono (not any other inputs). Its always been there with the volume well up past that but seems to be more noticeable now.
Any thoughts
John
Same issue here… wondering if its a ground problem? Is Something not grounded properly?
How old are the MC boards? When were they last serviced?
Thanks for that, I will check.
John
Hi Richard,
They came with the 52 in 1991. They were last serviced in 2012 as part of a service/Pots 8 upgrade. I’ve also recently noticed an increase in surface noise on lead in grooves and wondered if this was the Karousel/Radikal upgrade showing the limitations of the AT F 7 ?
Many thanks
John
Does the hiss change volume with the volume control? Is it the same when the turntable is disconnected?
Hi, yes the level of hissing does change with the volume control. It is the same when the turntable is disconnected.
Many thanks
John
If this has got worse only recently but was otherwise fine before, I suspect it could possibly be a sign that some service attention is again needed.
Is there a WiFi router or mesh router near by? Try turning off WiFi for a min to see if that clears the interference.
Preamp/Phono board issue.
If possible I’d probably take this opportunity to buy a separate phono stage rather than spend money servicing the boards.
Your level of kit deserves more than the Naim phono boards which are a real limiting factor for your otherwise top drawer record player.
Thanks everyone for your replies. I think you may have something there Bob, I was thinking on those lines myself.
John
Your NAC52 has a powered AUX2 with dedicated windings from the power supply, which could power a Superline. That would be a major step up from the internal boards.
Thanks Richard, I was wondering if that would be an appropriate option in lieu of an external PS.
John
