Just to be sure I am asking the question here.
Which connection should be the hot side when it is plugged in Naim equipment.
Or does it differs?
I thought left top one.
L = Hot. Since you are in NL you have a wall connector you can put two ways into it. You can get a phase pen to localise this if you don’t have it.
Thanks! and that is most common for Naim equipment of for mostly al equipment?
Yes that’s the normal way. But the connector type you show a photo of is not C19. It’s a C13. But the hot pin is positioned the same on them
Here’s a C19 IEC.
Thanks for your quick reaction. I also changed the title accordingly.
Maybe this will be helpful
