Hi how can i change a large spade to fit my naim nap250dr loudspeaker output exept cutting them please ,
Without cutting it, I doubt you can. I assume you need the banana plugs fitted? Naim actually make a special plug but would recommend these are fitted by a dealer as the soldering is tricky and not for the inexperienced!
Yes , i bought a pair of used MIT TERMINATOR 4 bi-wire 4.5m pair of loudspeakers cables 4 bannana plugs to two spades outputs each cable , ive just found something on amazon CNCESS CES -187 that might be ok THEY LOOK PERFECT , i have a naim uniti2 as a cd preamp & naim nap250dr poweramp , ive just bought a
BK electronics XLS300-DF subwoofer used , ill wire into my martin logan aerius i loudspeakers it should be quite a nice little set up ,then ill upgrade the uniti2 to possibly a used naim nac n 272 when the funds are availble
Naim plugs are the best fit and are best fitted by your dealer.
If I were you I’d think about some stock Naim NAC5 speaker cable with Naim banana plugs. Do not underestimate just how good these cables are with Naim kit. I still use them with my big Naim system as I’ve found little that can better them.
100%, the MIT TERMINATOR 4 bi-wire is not good for a 250. Bi-wiring halves the all important required Naim induction load. Plus that box ‘thing’ tunes out most all the inductance thats left anyway
Oowps my bad , ah well thats life , thanks for the reply
Google “Spade to Banana” connector. Bazillions of them out there.
