Here’s an outline about what this category is all about
Welcome @Godjo
Depends on headphone amplifier, but lets assume it’s Naim. This might help.
All the best!
Which headphone amp?
If it’s a Naim Headline, it’s a simple case of plugging the captive DIN5 cable into one of the tape loops.
If it’s some other headphone amp, then assuming it takes a line level feed and uses RCA phono, you will need a suitable interconnect - note it needs to be a Tape Out type at the DIN end to ensure the correct pins are connected to take signal from the Pre Tape Out pins rather than Pre Signal In/Source Signal Out pins.
