I have a Mu-So Qb mk 2 and the radio is not working. On a separate thread Richard suggests changing to the new Naim internet radio system. But unfortunately he does not explain how to do this. Could someone help?
Just go to the iRadio input and select the stations you want. Delete any old presets and save new stations if you use presets on the home page.
Check that your firmware is up to date.
Anything with a warning triangle on it is an old vtuner link.
Anything you find by going through the iradio icon is running on the Naim radio service.
It will not show you any vtuner stations.
Remove any old ones and find them again to save them.
As long as you have the newer firmware.
Thanks for your help. With the new radio stations many BBC stations are missing (eg BBC Radio 3 Unwind) - is it possible to add these in any other method?
Re. BBC 3 Unwind, this may help…
Thanks for that info. I think there is something wrong with the search on the internet radio. I could not find the old Naim Radio using search but instead found it nestled away under A-Z UK stations. Looks like the search only searches through the current menu, not through all stations. Is there a way to search through the entire radio A-Z?
