Unlike most other manufacturers Naim doesn’t use an inductor to stabilize the output stage in its amplifiers. The inductance is supposed to be provided by the speaker cable. This is the reason for the NACAs spaced conductors. As the inductance increases with length, longer cables provide more inductance. So you don’t need long cables to make the cables work, but to provide enough inductance for the amplifier.
So the minimum of 3.5 m length is also applied to the NC amplifiers?
As far as I know, and my knowledge is definitely limited, the OC amps already were in less need of inductance than the CB and olive designs. The same should be true for the NC, but I’m assuming things here.
Thanks @Mulberry , I asked @Richard.Dane the same question, but received no definitive answer yet. However, I recently tried 2x3.5 m NACA5 built by Cymbiosis, and it seemed to outperform the Kudos KS-1 cables of the same length.
As others have mentioned the older Naim amps worked best with the cable that had a minimum total inductance to make sure the output always remained stable. For a specific cable that has a certain inductance per meter this requires a certain minimum length to get the minimum required inductance. The reason you needed 8m or 10m lengths of NACA (even though this was not particularly practical for many people) was probably because Naim used a stock cable that was made in larger quantities by a bulk cable manufacturer and employed primarily for another application. This was also almost certainly why NACA4 cable was quite inexpensive when launched.
Ideal range is 5 to 20 metres. A pair of 5s means the least amount of cable for the ideal range is 10 meters off the spool surely?
I don’t really know what an ideal length would be and if there even is such a thing. I guess that some would argue that the shortest cable that meets the minimum requirements would have the lowest resistance and therefore be preferred but I doubt there would be much difference in practice.
It seems that the quoted minimum length of NACA4/5 is all over the place. When I bought my first set, soon after the NACA4 was released, I believe it was the “recommended” minimum length was 5m but maybe it changed since then.
For clarity I just wanted to note that the NACA4/5 have a lower inductance per meter than the specs quoted so its minimum length for actual Naim cables would be longer than 3m.
The ‘ideal range’ applies to bolt-down/chrome bumper and olive ranges.
I think back in 70s Julian did that to radically remove noise, and partly what made Naim’s power amps so successful – take the speaker cables as part of the speaker output and you will understand. Naim amps after olive range (OC, NC etc) don’t limit by this design.
Sean, there’s a difference between what an amp can tolerate and what it will perform optimally with. My understanding is that the NC power amps can tolerate more deviation from Naim’s speaker cable recommendation that the earlier amps - in other words, going for a short length of speaker cable or something with a bit more capacitance and less inductance likely won’t cause any damage to the amp. However, that doesn’t consider the adverse impact on performance that such cables can bring.
Re. cable length, in our own tests that we did in the dem room at Naim some years ago, I greatly favoured 5m per channel of NACA5 over 3.5m. 10m was preferred even more, but not by anything like the margin of 5m over 3.5m.
It is if JV said it, his word is gospel to the fanbois
He didn’t say that. He said designed to perform at 10m with range of 5 to 20m and a minimum of 3 or 3.5m. So I would take that as meaning the minimum is 5m for optimal performance and 3.5 for amp stability.
Obviously these figures are not cast in stone. Different amps will no doubt vary, and it’s not as if anything changes drastically as soon as you use a cable just outside any particular length.
My personal belief is that, way back at the beginning, Naim needed a speaker cable for a very specific set of parameters, so NAC A5 was developed. But the manufacturer insisted on a substantial order to justify materials and tooling costs, so Naim was forced to purchase several orders of magnitude more than they actually required. So the clever marketing department convinced the engineers that the solution was to insist ridiculous lengths of cable sounded better.
Unlikely, Naim is not that kind of company IMO. Not that I agree with everything they say, but I believe they are sincere when advising their customers. If it was linn I wouldn’t rule out that theory…
“Was”
Didn’t know there were any more of these bois left.![]()
No not at all. Just do the test of different lengths - 3, 5 and 10 meters per channel - on Naim power amps and you’ll hear for yourself.
Just for clarity we are referring to older products rather than newer ones. For example NN 50 states no such requirement whereas the Nait 2 does. Surely the NC series do not but I do not know re older 500.
Requirement for what?
AFAIK the Nait 50 and New Classic will respond just as well to longer lengths of NACA5 as the earlier amps as they also have no added inductance on their outputs, just like previous Naim amps.
Then its rather strange for me all the Naim I have/have heard - included NC and Classic, longer length cables sound better. 3M is a compromise.
OK, the latest boxes may not NEED the long run as much as pre 2000 kit.
