How come Naim sells 3m super lumina?
I thought the Nait 50 instructions did not,unlike older Naits, specify a minimum speaker cable length. Maybe I am wrong and all Naim amps need a specified minimum speaker cable length.
I do not doubt your experience. The point I was trying to make ( and failing it seems) is I did not think Naim stated for newer products the same minimum speaker cable length. Clearly I am wrong.
And just to be clear you have heard all the most recent with differing cable lengths to support your statement
The NAIT 50 manual states the following:
Unlike some earlier Naim designs, we do not mandate a minimum speaker cable length, but would still suggest you avoid sub-2m lengths.
IIRC Steve Sells mentioned that the current Naim amps are more resilient than earlier designs to short lengths of speaker cable. However, that’s more about the possibility of shutting down or potentially damaging the amp than about sound performance. In other words, just because you can run short lengths of speaker cable, doesn’t mean that will give you the best sound performance compared to running longer lengths.
Did I just notice a bit doubt after all ![]()
They haven’t asked me before release, if thats your worry.
Apparently they still do for my Nait 5i so it must have been relatively recently this changed. Mine are actually a 3m pair.
Fair enough I have misunderstood the previous advice about cable length.
You can use shorter without damage but will not sound as good. It’s a shame after opting to get 3m rather than 5m I had for the 50.
You live and learn. Thank you
Surely one has to take in to account the crossover network in the relevant speakers being used when talking about cable length effects, it all collectively forms the LC load as seen by the amplifier and the cable alone can’t be considered in isolation
How did you reach this conclusion?
Thanks for clarifying Richard
The inductance per meter of NACA4 is about 40% lower than the lowest inductance JV gave in his e-mail. Therefore to have the same total inductance one would expect the corresponding minimum length of NACA4 to be about 40% longer than the 3m quoted.
Looks a good job there, couple of questions if I may:
1; “heavy duty Deltron plugs”? I can’t find such a product, I’ve found 579, 550 and 584 plugs on one site and none of them mention ‘heavy duty’, can you clarify please.
2; have you shrink wrapped part of the arrangement? (looks like it, and a good job it looks too)
Many thanks
Hi
Thank you yes.
They are part no.
Deltron component part numbers:
584-0100
584-0500
I get them on the bay from Compass Audio.
I say heavy duty but they are large bucket it’s the biggest one they do. ![]()
I have some of those, waiting to be called into action.
I’m tempted to buy some Mogami speaker cable, sounds like excellent value. Although I’m not experiencing any harshness or lack of detail with the NacA5.
I have some in the loft you can borrow if you like ![]()
When would you want it back.
Just after I solder the plugs onto it. ![]()
Comes with excellent bananas ![]()
I am not so sure as both cables would appear to have similar inductance.
The figures that I could ascertain for each cable are -
NAC A4 Approximately 0.93 µH
NAC A5 approximately 1.0 µH/m nominal but measured to be 0.95 µH/m in 2019
