How it looks / not how it sounds
It did run very hot indeed, and unfortunately, the lightweight plastic controls on the front of the amp gave the impression that it wasn’t very well built. I bought one back in 1984 when it first came out and it sounded reasonably good, but I replaced it pretty quickly with an Audiolab 8000A which had a hugely better build quality, sounded significantly better to my ears, and is still running flawlessly all these years later in one of my systems.
I still have the A1 tucked away in a cupboard somewhere. It was only used for a year or two, but I suspect it would not still be working today had it been in constant use.
Balabo is by Japanese Fumio Ohashi. I just verified. Perhaps it’s associated with California some else ?
I got 30 years good service from my A1 before it failed to power up one day last year, and that includes taking it to America amd having it converted to run off 120v and converted back to 240v when I came back to the UK. It was a simple and inexpensive repair and it is now out on loan to a friend and still sounding good. I should be thankful that it did fail though because if it hadn’t I’d probably never had started out on my Naim journey.
I stand corrected. You’d never guess this from the info on balabo.com though. Terrible site.
am i wrong feeling zen? i read that on absolute sound.
Pretty sure my last comment says you are right.
i just went on google, found on site balabo. com: made in usa. But impossible to enter the site. So all curious…
Well it has the same products as the Japanese site. Balabo=Bridge Audio Laboratories
US site contains absolutely no company info other than a California address.
I think they just have a very dodgy US distributor.
soulines turntables
Yar system: amp and speakers. 250 000 euros…not conventional
The Vertere Turntable, good looking or not, I know it’s sounds stunning :smiling_face_with_sunglasses:
In my view PB it looks superb in black.
L
A black one is called a TMS @LindsayM :smiling_face_with_sunglasses:
I’m very fond of the looks of Touraj’s previous deck, the Roksan TMS.
Wow, great timing.
PB. Out of preference I prefer the Xerxes and TMS aesthetics but sound wise the jury must be out.
L
basis debut turntable, in black or transparent. Look a bit like Vertere. But don’t know if it sounds the same…
I think it looks better with the lid off :sunglasses:
Vertere, in black
My beloved B77 - sound every bit as good as it looks. Not bad for something
made in 1980!
