Hi there,
I am trying to connect the Naim Uniti Phantom to a Devialet Phantom. I am trying to use an optical cable. The 2 devices are connected. The Naim website says to then select the Optical input, which I guess is the Digital 2 input. It does not work. What am I doing wrong?
Perhaps @james_n might know
I’m assuming you want to play music from the Uniti through the Phantom ?
It looks like the Phantom has an optical input but the Uniti has no optical output so this won’t work unfortunately.
