Hello to all of you. How is it right and safe to connect this subwoofer to this system? Of course I will use the speakon input for a high level. Thank you in advance for your time! Health, Good Luck …
Hello again. Do I still hope to get competent advice on the safe and proper connection of the subwoofer with my other components described above? Thanks and Cheers !!!
