A good friend of mine wants a system to play his collection of lps( size unknown).
He has heard my system and wants to have own set up.
But here is the rub, he has a limited budget. Likely to be about £1000. All in.
How do I advise?
He would be intimated by a dealer. Not least by his budget. I need to play this carefully as he has put this decision once before as it got a bit hard for him.
Speakers will be second hand. And sub £100? From eBay?
Cables I could provide for free ( but he’ll not be getting my RCA Chord Signaures)
A second hand integrated? MF Xa2 can be had for £200ish. Doubt he’ll get a nait for that.
A phono stage is likely to be a cheapish rega?
TT. Rega 1 or 2 or what?
Whilst the budget is £1000, he’ll want to spend less. So I need to tread carefully. But I do want him to enjoy his vinyl again.
I think a used RP3 and some used bookshelf speakers for £100 would be the mark. A Nait 3 with phono stage would be within budget. Linn K20 speaker cables to keep price down. Maybe a used CD player and rack. Should be able to do it all within £1000.
I started with a used rega 3. This guy is unlikely to want to upgrade. What he starts with will be it. Lucky sod.
But sometimes things like a used rega 3 can be not any better than a rega 1 or 2. Assuming rega improve stuff as times go on, and previous owners have not buggered anything. Otherwise the new rega 1 starts to look good.
I’m going yo have to be carefull here.
You know what it’s like suggesting stuff, then even pointing to certain “bargains” on ebay. You end up being the first line technical support!
I’m OK with where where cables go etc. Just less interested when it goes wrong. Especially if they’ve buggered things up!
Good point. Forgot about Richers. Like you said, you’ve got to know your stuff before you go in otherwise any guess what you’ll get sold.
Although perhaps less intimidating to most than our favourite proper hifi shops.
That rega system one. Definitely, don’t muck about, for 999 it’s an absolute bargain. We saw it at the launch at Bristol hifi show 2020. Omg that set up grooved. It’s like buying an amp and speakers and the rest … turntable and all cables… are thrown in for free.
