Not sure if this is allowed, although I’ve tried to clarify, so here goes:
Has anyone used a hydra-type cable to connect their equipment? I understand it implements star earthing, and is supposed to improve performance. I am considering giving it a try and wonder if anyone has any experience of using hydra cables.
I am using a Custom HiFi Cables PowerBlack Distribution Block with 8 outputs. The Block is fully customizable and the build quality is excellent. It was an improvement over the music-line “Netzleiste”. I can warmly recommend it.
Sure, the Custom HiFi Cables PowerBlack Distribution Block is a star earthed block just like the Hydra. The advantage over the Hydra is that it can have up to 13 outputs and that it is fully customizable.
There’s a thread on power blocks iirc that covers hydras in which iirc Richard Dane recommends them for and says there that Naim used to use hydras in house.
I would only buy a hydra if I knew that I had no chance of getting more or less boxes for many years to come. But I’ve never been in that situation since learning that they exist.
Before buying a hydra I’d consider investing in individual Naim Powerlines
But if buying Powerlines for say 4 or more boxes you’re spending a grand, which could be spent instead on a dedicated radial or ring. With a hydra or Powerlines lites or Powerlines ?
So the electrical supply options can be quite complex and are probably best considered as a unified part of the system.
And I like to leapfrog intermediate steps if possible.
At the moment, I use the standard Naim cables, as they seem to work pretty well. They are plugged into a balanced mains unit, so It’s possible there is start earthing there
I may soon end up with a 3 box system, plus a Cisco, which I’d be very likely to not change for many years.
So then I could get a hydra.
But should I get a three or four lined Hydra?
ie to include the the Cisco in the hydra, or not?
