My Naim 332 seems to have not come with cleaning cloth. Is it in the 300 series document package which I have not opened? If I can’t find it, can I use a microfiber cloth? Is it only a UK item and mine came from Focal Naim USA? Thanhs.
I think it was folded and in the sort of cardboard envelope thing with the brochures and an ad for Spotify. It’s a microfibre cloth, I’ve added mine to the eyeglasses pile. Mainly I use swiffers to keep my (new) 222 looking nice. Congratulations on your new system, very good pick I’m sure!
I would use a swiffer before the cloth that comes with it. I would avoid touching or wiping the acrylic as much as possible otherwise you will see swirl marks in certain lighting.
Congratulations on your new gear! You are in for a treat!
Hagel, any specific Swiffer?
No. Where can I find that?
If you can’t find it. The best solution is to buy a lens cloth for spectacles. They are made not to mark or scratch lenses.
Even if that one is missing there should be two others that came with the 333 and 300.
It isn’t the cloths that scratch it’s usually rubbing the dust and grit starting the polishing process.
This is fine. ![]()
The swiffer looks the same as the dust magnet. Use it to get the dust off and use the cloth to wipe off finger prints.
