Is anyone using the IKEA Kallax to store LPs? Is it sturdy and doesn’t sag?
Would appreciate real live pictures with LPs.
Do a search on the Forum for Kallax – use the Q-looking (spyglass) icon, usually top-right on the screen.
Yes, very sturdy if built correctly (hard not to!) and used on a level floor.
Here are 2 of my 5 ‘cubes’, great for vinyl…sturdy, had no issues, and survived a house move..
I have ‘feet’ on the floor facing units..
I have a 5 X 5. Important not to tip it on its side with a big unit, it may collapse.
You’ll notice I’m not totally selfish, I’ve allowed my wife to store her crosstitch cottons in one of the compartments.![]()
Kallax is quite popular. I use Form Konnect which has the advantage for me of having a backing board. You can also buy shelves as seen here.
I couldn’t be asked to go into the garage to take a photo of my vinyl stored in Form Konnect but I have 1800-2000 records, plus books on a floor to ceiling array.
Yes. Yes and No.
Ok…?? ![]()
Oh my… ![]()
Ouch!! If that’s yours was any vinyl harmed!?
It’s a bit pricey, but a vote for Tylko here. Easy to put together, stacks, and very good customiser app.
It’s also made of ply, and seems exceptionally strong.
I use their “vinyl” storage template for vinyl, and a standard backless unit for CDs
No. Not mine.
I make sure the long shelves are horizontal and the short shelves vertical. ![]()
Thank goodness! But also feel for whoever it was, I would be fed up if that happened X)
I use a 3 x 4 for my LP’s. Seems sturdy and no sagging. Very happy with it. ![]()
Just today I was asking myself the same question and starting to see some photos because I was undecided whether to take another glass piece of furniture …
I use them for mine, they are pretty solid and good value for money
Nice to see you’re sharing with your cat.![]()
