Hi all I have 2012 Uniti 1 I’ve got it paired with some 40year old linn Kan MK1 that are looking a bit long in the tooth. So I’m after some recommendations for inexpensive bookshelf speakers think q acoustic. I’m in my late 30s with a young family hence the need for bookshelf I’d them to be as understated as possible so clean aesthetics would be welcomed.
I’d say nothing above £500 at this point in time. I imagine I’ve probably answered my own question with the q acoustic reference but was wondering what people’s experiences are or what they’d set up for a 2nd room office set up something like that.
We don’t listen to a much audiophile quality music just a bit of streaming, cds and radio on the uniti.
The Kans are excellent speakers and far better than anything you’d get for £500 these days. If you are happy with the sound, maybe a bit of wax on the wood would perk them up looks wise.
I think that might be what I do to be honest. Nostalgia alone will make me keep them. The cones a little damaged from years of being poked no holes or anything though.
The fabric covers have had it in my opinion though but I don’t really know what or how to replace them. What fabric did speaker covers use
I think they could do with a light sanding and then sealing.
If you are not in too much of a rush and don’t mind second hand, you can get real deal, take the occasion to try some speakers for a while, if you don’t like then you can sell without lost. I see (in Canada) a pair of ProcAc Tablette III for 500 $ Can. That’s not much in. B pounds.
My hidden point behind all that is even if it’s a second or third system, if you are going to use it often enough you probably are going to miss the nice feeling of good sound. This is what is happening to me with my KEF LSX in my kitchen/dining room…
I bought a pair of Q Acoustics 3010i during lockdown and was delighted with how good they were on a small Naim rig.
They are supplied with foam bungs for the port, making them easy to place. They are so efficient you will think you have a NAP250 fixed to your Uniti 1.
My first thought was Tygan mesh, then the only pair I have handled had been refinished.
There is a manual on Manuals.lib that is rather confusing because it says there is no grill frame to avoid rattles, then describes a process that suggests there is a frame. Other fora refer to taking care not to crack the frame when removing!
Good luck.
I would definitely keep the Kans as long as they sound OK. Not sure about the grills coming off. My pair had a warning on the back “Do not remove grill” so I assumed that they were glued in place or something. I’ve never tried it though.
