I discovered that with assisted ripping mode set I could control the rip better. The important thing with CD sets is to set the number of disks and then sequence each.
The Zen mini has output features that models higher up the range don’t have such as toslink and coax. The model up the range concentrate on dual and then triple LPSs. I can’t understand how that would improve uPnP as that and USB are the only outputs. Anyone understand?
I’ve been doing some serious ripping, and I have to say it is really good. It’s never found the wrong album and most of the time chooses the right album artwork. It’s very easy to change the cover. It even does a great job with classical box sets. The Opera set mentioned in the first post resolved itself once I understood how it does box sets.
I have been in contact with their support and found them to be extremely helpful. The models up the range which only have USB (uPnP is standard) can work with spdif by the addition of the M2Tech converter which they offered to loan me! The addition of the LPS should improve the sound quality further.
To my mind their Zen(ith) models are all the Core should have been, and the sound quality is as good as my CDX2 as a transport. The addition of the LPS should improve the sound quality further. And it runs Roon Core!
Thanks for the detailed answer. It would be great if the SQ, on top of ease of use, is top notch on this thing.
I’m going to a local dealer next week who has an NDX2 for me to listen to. I’m going to compare internal tidal vs Zen tidal going direct into the NDX2 to see how they compare.
Finally put this question of just how much streamers impact SQ vs it all being the DAC.
I think you might be surprised if you already have nDAC. I see it as at least a relatively inexpensive step towards streaming, and of course you need a music server (uPnP) for Naim Streamers.
I have an nDac, which I’m very happy with. I just recently took home to demo a DCS Rossini. I couldn’t discern any real difference. My wife and I did a couple sessions and saw no value in changing.
So my plan is to find a great streaming source, and based off what I’ve heard, the NDX2 is a great device, so in my eyes, if I can run zen into the NDX2 at a dealer and see if it sounds the same/similar… then the zen is a great stand alone investment.
FR, I don’t know who Jason Kennedy is. I know @BertBird and possibly @Darkebear use Melco with their ND555.
The main points I am making at the moment are that the ripping is very good and SQ over toslink into my nDAC possibly better thank my CDX2. I now have suspicions about whether my CDX2 CD transport laser needs a clean after 3 very heavy years of use. My dealer has offered to clean it. Any warnings about this.
I’ve been trying the RCA output: it really is a noticeable improvement over optical toslink, which is what you would expect. Considering the CDX2 uses a Chord Clearway BNC which should be better this is quite a surprise!
I really can’t praise this little box enough. Perhaps I should let you know the 1TB retails at £899! Just the quality of the metadata lookup would justify the purchase for those who don’t want to use dBPoweramp. iPeng is a good App for managing playback.
Phil, are you talking about the coax digital out (which I assume is RCA) or do you mean the analogue 2 x RCA output? If you mean the latter, that would be quite a claim, with the built in DAC on a £900 device beating an NDAC or CDX2.
As recommended recently I have put my Cisco 2960 between the BT HH5 and the Zen. It cuts out some noise over the Ethernet connection. It makes a noticeable difference to the whole soundstage. Shortly I will use an AQ Forest Ethernet cable there.
