I can also get a burnt in unit (so they say) (ex demo) from another dealer or a new one from my dealer - which I need to burn in (not so much different in price).
New one or burnt in demo (unseen from www)? I tend to the new one, as the dealer is very nice!
If standing unused in the shop, there is also burn in needed. Recognized it with the demo unit. After a week now it shines
No, I use Sense. To tell you the truth, I canāt remember how I burnt in the Statement. I think I just left it playing radio. When I got it back with the NextGen power supply, I just listened to it as normalā¦ I may well have posted about this but canāt remember. Will try and search here tomorrow if you canāt find it in the meantime
Ne t strange thingā¦ did not find any radio station in the menu - all empty
Solved - also only running when streamer attached via upnp bridge
Iām pretty sure there was no burn in at all on my zenith. Just listen to music, it will be fine
Here we are ā¦ at last hours before decision to be madeā¦
As usual I am mr. Doubt at this time.
The Innuos is different to hdx - that is for sure. It is also different to melco iirc.
Hdx is:
- darker in tonality ( like that) - real darkness came with PN
- all is together (and less separated) - also a bit more relaxed.
- something a bit metallic sounding.
- has a real nice āblackā bass
- soundstage is a slight bit laid back
- a bit less bass weight than hdx
Melco n10 was:
- totally resolving - really very much details
- smooth sounding (but brighter than hdx)
- not so deep soundstage as hdx
- no harshness and very silky sounding
Innous is:
- more details than hdx (you can hear a lot more) - but iirc a bit less than melco (but could be the same)
- very forward playing (sound jumping on your hip)
- a bit brighter than hdx
- soundstage not so deep as hdx - all is coming a bit upfront
- sounds happening in the background are louder and nearer (also more detailded)
- voices are stunning (very much emotion) best of all 3 (but with ee8 voices were also good - went a bit back with PN)
- piano - see voices
- the experience is like live - never had this before that I imagined a band playing in font of me (sucks you in)
- sound is rough - like it (olive like) - edgy
- very much prat - more groovy to my ears than melco (melco more relaxed)
- roughness is sometimes a bit too much (sounding a tad mechanical at some songs)
If Innuos will be a bit darker and rounder/organicā¦ think it will be named statement
Fidata looks also fine but is rare to get.
Think I will miss the innous more than I will keep staring at a āall in mindā roughness at 1% songsā¦
What innous definitely is doing more than hdx. Showing you the good and the bad of recordings - but not in a bad way. It is sounding overall better than hdx - and if a bad one is in the stream you will notice more.
Ordered a 4 tb Innuos zenith mk3.
As far as I understand, there is only a ābiggerā ssd (one. With more storage) included and not 2 x 2 tb.
Audioquest dragonfly?
Yeah, I though about this option
Hi
Is a dragonfly black ok?
Only for burn in period or should I go for a Ifi DAC (a bit more expensive but with own psu)
Iāve never heard either of those dacs.
But Iām sure others will chip in to help you decide.
I Need it only for burn in of zenith and afterwards ?ā¦.
You mentioned a Chord Hugo earlier in the thread, do you still have it ? If not something like a Dragonfly would work or an M2Tech which would get your system working using the ND555 as Dac/streamer.
I have been an Innuos user for a number of years, Zen, Zenith and just recently Statement, I have never been too concerned with burn in.
Have you thought of buying used / ex-demo ?
Will save you a chunk of cash (especially if after minimum 2TB) and will accelerate your burn-in period.
The units really are bullet proof and not a lot can go wrong. Innuos support is also 2nd to none.
I bought a 2TB Zenitth Mk3 used and itās been one of the best bits of equipment Iāve owned.
Hi
I want it now and there was only one 4TB available ex-Demo, for not so much less.
The used ones are a better bargain, but they are all 1TB (or silver ). Would have taken 2TB, but 4 gives me a better gut feeling. I tend to take different versions of one album (cd and 24bit / hdx rip and melco rip ā¦ )
And the dealer is nice and he is 5 min away - thatās also a good one if something goes wrong.
I have no other ideas as Innuos being bullet proof.
Currently listening to Lou rhodes ā¦ wowā¦ zenith is capable
Hi @JimDog Yes, I have a Dragonfly Red which I bought to use with my iPhone, and an old black one which works with computers but not phones.
The Red is pretty good considering the size and price, although I only use it with IEMs so hard to say how it would compare to a āproperā hifi setup.
My experience fwiw
Innuos subsequently added ethernet functionality to the nds which I use today.
Hui
Zenith arrived - now acclimatizing.
What I saw is, that this unit has different feet - instead of 3 mini silicon? pads per feet, each feet has one foamy pad - the foot itself is identical. The slight wobbling factor is identical to the demo unit. Hope that this is improvement or alternative instead of running out of mini padsā¦
The one pad is actually MUCH more practical on the Quadraspire SVT - but currently running on fraim glas
Hi Guys.
need your help.
All setup and burning in - my dealer gave me a DAC on loan for burn in period.
But had no chance to wire it up yet - burning in even without player output.
I would like to use it during nighttime.
Question:
Is it necessary to plug out the Ethernet cable from LAN Port (connection as server), when DAC is plugged in via USB and Innuos is set to play.
I really like to keep it in as cable dressing ā¦ you might know
THANKS!
