Windows 11 will be getting support to run Android Apps in a future update, so it may be possible once this happens. Then again an old PC may not be able to run Windows 11. If you need to update the laptop I would suggest the M1 MacBook Air. The battery last ages, runs cool and is well built; a joy to use. I also have a Surface Pro 8 and it just can’t compete with the M1 MacBook Air.
@Richard.Dane I received a system message that my post clarifying the [edit] “thing” was removed. Not sure if my reply to this system message was delivered to you. Could you PM me please? I’m confused, the post by PW42 above is still here, I can’t understand what was wrong with mine. Thx
