My system comprises:
52+Supercap
SNAXO242+Supercap
2 x CB250
SBLs
I’ve got a question about the interconnect I can use between the supercap feeding my 52 and the supercap feeding my SNAXO242.
At the moment I’m using a grey SNAIC to pass audio between the two Supercaps but I believe only three of the connections are used (earth, L, R). I don’t believe that HiLine is made in the necessary 4-4 configuration.
SuperLumina seems to be available in 4-4 but I’m wincing at the price… what would my options be from Naim? Would a 4-4 ‘Active’ cable be second best?
I only ask because I think the HiLine that replaced the 5-5 Interconnect between my nDAC and 52 has made the system a little more enjoyable and I wonder if there is also a gain to be had on this link in the chain.
From the SNAXO242 I’m using the default Naim cables to the 250s.
I found it gave a better uplift than swapping from Hi Line to SL interconnect on my NDS source for instance. Putting your best PS on the crossover also makes a lot of difference suggesting that this part of an active system is maybe a bit if a ‘choke’ point?
Interesting. Thanks. It’s about the cheapest Superlumina interconnect but even so a substantial investment. My local dealer isn’t a fan of SL so looks like I’ll need to head further afield again to see if I can borrow one to test that out.
