Can someone try streaming the 24/192 version of this album from Qobuz to see if you also get the pauses/interruptions
Yep, pretty consistent here too. The apps shows it entering pause.
OK thanks so its not “just me”.
Although oddly I had a power cut which restarted my system and my home network, I tried it again and it played through that time. I’ve flagged it to Naim development.
It is a particular problem with 192/24 streams on Qobuz and is particularly noticeable when everyone using Wi-fi at moment. If a continued problem then go into Qobuz settings on Naim app and select quality as 24/96 rather than 24/192
