Interner radio streaming
Appeared some time ago here, with no solution. Muso Qb2. Occasionally the radio signal would vanish after 10 minutes or so, and after pressing ‘play’, or the station preset, it returns — for another 10 minutes or so. Infuriating. Spotify works fine without any problem.
Has anybody else experienced this behaviour?
Are you using it wirelessly? If so, try wiring it and see if it fixes the problem.
It happens to me sometimes and my system is wired. variable in frequency and a power cycle normally resolves.
