Hi everybody,
since last year I’m an happy owner of a Mu-so 2nd gen.
I couldn’t find Radiodeejay, an italian web radio, so I followed these instructions, kindly posted by Steve:
RE: Radio DeeJay I will ask VTuner if they can add it to their directory. One issue I see is that it’s in HLS format only so will be limited on devices that can play the stream. As a short term work around you can add the station at naim.vtuner.com using URL: http://radiodeejay-lh.akamaihd.net/i/RadioDeejay_Live_1@189857/master.m3u8
The quality is quite low (46kbit AAC HLS), but its the only stream that seems available.
The solution worked fine till last week, when suddenly Radiodeejay on my Muso has gone mute.
I checked VTuner, reinserted URL… nothing.
Please can you help me?
Matteo
