I’m big fun of Naim All in One Systems but my Naim Nova is after 3 years driving me crazy and I’m asking my self does it worth my patiens?
Everything is working and sounding as expected from Naim except the INTERNET RADIO!!!
It’s frustrating!
Working for some time or minutes then breaking down and getting up. Doesn’t care if it’s wireless or wired connection.
I don’t know how many factory resets I made…
No proper results.
All other devices on wirelles net working fine.
Wven connection trough wireless net with Synology is working with big flacs without sny problem…
Anybody knows something more on that?
Miki
if the issue occured with both wireless and wired connection, the internet box/modem may be responsible…you may call your operator in order to check your line
What stations do you experience problems with. Many of us has used internet radio for many years, and unless vtuner kills the access to streams this works fine or worked finer in the past.
All stations Radio Paradise Naim… playing for 1 min then stop and maybe come back.
As I mentioned all other devices on my wifi works well included in that NAS disk playing on Nova trough wifi with no problems
