Good afternoon, from Dee Why, Sydney. Despite even the best brains from Naim on the case, I’ve been unable to get graphics (such as radio station logos) when using the above. It was suggested to me I uninstall & reinstall said app. Done. But to no avail. Any other ideas, or, especially, a hard-&-fast, failsafe fix, would be mightily appreciated. I’ve been putting up with this for a number of years.
Have you reset the router? (though I would assume if “years” then yes). Do you use a vpn?
What do you see instead of this?
