I plan on doing a small amount of metadata editing on my ripped flac files. My files are on a thumb drive that I can connect to my iPad Air 5th gen with a USB C hub. I was hoping you knowledgeable folks would have some recommendations!
I found this thread:
but it is a few years old now…
Ideally I would edit the file directly on the thumb drive, but it might be that I need to copy them to iPad first (I will experiment).
The one I use & it does it all & far more than I would ever use is MP3Tag … open source (free) but voluntarry donations are requested
Don’t be out off by the MP3 name, it does all the lossless & lossy format/codec
Not that I’m aware, not even sure how to upload a FLAC file on a tablet type device, plus I suspect a non Apple licenced FLAC on an iPad might cause issues with Apple.
Ah OK. MP3Tag is available in the App Store for Macs, so as you probably know, once you have purchased it the once, it will be on all your Macs forever more
For IOS, there is a version of MP3Tag available under the name Evertag. I have never used the PC or MAC versions of MP3Tag so I can’t vouch for how similar it is, but it certainly works. It is not well documented though and the developers don’t respond to emails.
I use Metadatics, great functionality and (for me) an intuitive interface.
I was using it yesterday to ‘curate’ a digital album of guide tracks for my wife’s choir - so it provides track numbering and you can choose your own cover art.
For some weird reason I never have cover art set when I download individual pieces from Apple’s music store, so I use it to set the artwork.
So do I (except for CD rips, where I use a Naim ripper that has an iOS app) but the OP wants to use an iPad. I’m sure there’ll be a suitable app out there somewhere.
