As per another couple of posts, I too have an issue with the app not allowing me to change radio presets.
Regardless which preset I chose, it played the same radio station. One not even in the favourite list. I then deleted all presets and tried adding the original stations. But there are no Add Preset options anymore.
Did you try a power off restart of the product and closing and restarting the app?
Best
Yes. I even went as far as factory resetting the Mu-so.
