Is there still a BBC Radio 3 320kbps stream that one can add to vTuner for the iRadio on a UnitiQute v1? I added one back in 2012 or so:
Station name: BBCR3 HDTest
Desc: 320kbps Test
Station URL: http://87.248.208.73:80
Genre: Classical
Type: AAC3
320kbpbs
My UQ says “Can’t Play Station Unavailable” I guess that’s gone … if it ever worked.
I ound a link for a different stream:
http://a.files.bbci.co.uk/media/live/manifesto/audio/simulcast/hls/uk/sbr_high/ak/bbc_radio_three.m3u8
Which shows up in VLC as:
Codec: ADTS
Sample Rate: 48000Hz
Bits per sample:32
One can’t input this to vTuner as an IP[v4] address, port and/or some other switch are required.
Using Wireshark when playing the file I found there are three IP addresses where data is sourced: 23.50.57.114, 23.50.57.129 and 23.50.57.147 - all from port 80. I guess all from behind a load balancer, however a search on network-tools (so slow these days) and ultratools brings up a whole bunch of other IP addresses.
I’ve tried them all [edit: the 3 wiresharked addresses] in vTuner as /80, http://address/80, and combinations of AAC, MP3, 320 - and as the bitrate field doesn’t specify units - 320000, 320,000
How do I add this channel and the other BBC 320 channels.
Do I need the 192kbps board?
Many thanks in advance.
