Have the two rows of buttons on a nac 282 synchronised? I.e. CD also changes the record to CD also.
System automation only changes the top row. Not much help when using headphones, driven by the bottom row.
I’ve read the manual, but can’t see any way of doing it.
You can control the bottom (record) row if you first touch the ‘rec’ button on the remote.
‘pre’ enables control of top row, ‘tun’ is for NAT-05 presets
Thanks, must have missed that. Although I find have to find the remote to try it!
